From a 2002 2.4 turbo. Has cooler in the pan. I believe this is from 2001 ? On (someone please correct me if lm wrong). It is an upgrade for earlier models including 850s. I have the tubing for it also. In north Delaware. Calls are best. 302-981-8223.
Other engine parts available
5cyl oil pan with oil cooler & lines
- Has thanked: 17 times
- Been thanked: 35 times
You never gave your asking price!!
Thanks you!! It's always nice to what the asking price it.
This is a good deal for someone who needs these!
Bump
But also, how is it an upgrade for the 850's? Larger capacity? Better flow? Sub-Atomic Filtration with Flux Capacitor?
Thanks
Thanks
1994 854 Turbo Metallic Turbo Red (Burgandy) / Charcoal Grey Interor
1996 855 R Black / Tan Interior
1996 855 R White / Charcoal Grey Interor
- Has thanked: 311 times
- Been thanked: 817 times
Advantage is the new setup takes the oil cooler out of the radiator.
- The old style hoses are a royal PITA to install and maintain and the new setup eliminates them.
- With the old setup there is danger of mixing oil and coolant when/if there is radiator failure, happens from time to time.
- Has thanked: 2207 times
I believe this fits 99/00 V/S/C 70 models also. They moved the oil cooler after 98 to the oil pan.
