Squeaking noise during cold idle
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
Hi guys. I have an intermittent squeaking noise that occurs when the engine is cold. It sounds like it's coming from the passenger side and I have replaced several components either to try to fix the noise or for unrelated reasons. I have replaced the serpentine belt twice. The serpentine belt tensioner, the alternator for unrelated reasons, the timing belt, idler pulley and tensioner along with the water pump for unrelated reasons. I tried spinning all the pulleys with the serpentine belt off and they all feel smooth and appear to spin straight when the belt is on. Could it be the harmonic balancer?
Matt
2000 V70XC 160,000mi.
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
Sounds like a bearing of some sort, if you spin the pulley's with the belt off there is no tension on it. Adding pressure can cause old, worn out bearings to slack a little bit. If you have the chance have the hood open and listen as best you can to see if you can narrow it down. Does it go away quickly or under acceleration?
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
^^ agree with the above.
Two ideas for you:
1) Buy a cheap mechanic's stehescope and see if you can use that to narrow down the area where the noise is coming from.
2) Remove the serpentine belt and start the engine. You can safely run the engine for a bit as the water pump is rotated with the timing belt. If the noise stops, at least you know that the timing belt side of the equation is OK.
The harmonic balancer is directly attached to the crankshaft and does not have any bearings itself.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
If none of those are the squeaky part, turn off the fan to the AC/Heat to make sure it's not the blower motor. From inside the cabin, it could sound like it's coming from the engine bay.
m96ag
Post by m96ag »
MadeInJapan wrote:If none of those are the squeaky part, turn off the fan to the AC/Heat to make sure it's not the blower motor. From inside the cabin, it could sound like it's coming from the engine bay.
I tried it with the blower and radio off. I'm going to try running the car without the serpentine belt.
Has thanked: 1609 times
Been thanked: 4064 times
Get to the bottom of this before you drive this car. You can easily pull a 3000 USd job if TB fails
m96ag
Post by m96ag »
abscate wrote:Get to the bottom of this before you drive this car. You can easily pull a 3000 USd job if TB fails
The TB was replaced along with the water pump, tensioner and idler pulley
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
On my 850, it was the tensioner for the serpentine belt. Replaced that, and discovered that about 80% of the squeak was gone - the rest is apparently the alternator, which I'm keeping at bay with some bi-weekly sprays of a little lube. :)
- S
[Sold] '97 S70 T5
m96ag
Post by m96ag »
Sommerfeldt wrote:On my 850, it was the tensioner for the serpentine belt. Replaced that, and discovered that about 80% of the squeak was gone - the rest is apparently the alternator, which I'm keeping at bay with some bi-weekly sprays of a little lube. :)
- S
Both of those have been replaced.
Sommerfeldt
m96ag wrote:Both of those have been replaced.
That doesn't necessarily exclude them, though. ;) 101's suggestion is the absolute best - either buy a mech's stethoscope, or use a length of vacuum tubing as one, and track down where it's squeaking. There are so many moving parts there that its's really the only option.
- S
[Sold] '97 S70 T5
