How To Fix Back Of Center Arm Rest
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
A while back while sitting in the drivers seat i leaned a little too far to the right and pushed the center arm rest over too far, and the hinge bent and it broke the back section of the arm rest where the second cigar lighter is located. I would like to repair that or replace it somehow.
For one thing, the hinge itself is way under designed, with the metal being too thin. The plastic on the back must be too thin too. What a cheap way to design such a thing. The arm rest swings up to reveal a compartment underneath, but it must weight in at some 5 pounds so it should have had a strong hinge and tough plastic mount. It's kind of a silly mechanism too, where there is no latch or lock to keep it shut, only the weight. And also no front supports to keep the front part of the movable part from swaying right or left and flexing the cheap cheap hinge. If i had to guess i would have said that part was designed not by Volvo but by Chevy :-)
This is typical of what i seem to find on this car though, on the one end of the spectrum. Some things are designed really really good, and other things are designed really really stupidly. It's one or the other :-)
So now i have to fix it. Any ideas how this should be done? Where do you get a replacement for that?
Or should i just redesign it so it is as strong as it really should be?
Thanks for any ideas on this and any experience with this.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The center arm rest does have a latch, it latches shut on the center console. Maybe on yours the latch was broken already.
The best way to fix the hinge mount would be to replace the center console, that's what I would do. You can maybe get a new arm rest at the same time, one with a latch. Or is the latch there, but its attachment broken on the console? That would also point to a new console. Fairly easy piece to grab at the pick-n-pull.
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
Pick and Pull is easiest way. I am getting ready to throw an old one away. Pretty sure it is in good shape, just tired of holding onto everything.
Let me know if you can't find one and pay for shipping on this one.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Has thanked: 1609 times
Been thanked: 4065 times
If you have the charcoal grey interior, JB Weld is almost invisible - it is invisible if you add a bit of carbon black to it.
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
I did this too had a hard time finding a good one at picknpull so I cut the back out a bad one and attached to my old one with epoxy and a couple of torx screws and some hidden aluminum to reinforce- better than new and you cant see that part unless the seats are reclined
MrAl
Post by MrAl »
erikv11 wrote:The center arm rest does have a latch, it latches shut on the center console. Maybe on yours the latch was broken already.
Hi,
Yes mine never had a latch when i got the car. So i guess it was missing all along.
That is probably why it broke so easy then, because the latch would have prevented the front from swaying too far and thus stress the plastic at the back.
MrAl
Post by MrAl »
obayha wrote:Pick and Pull is easiest way. I am getting ready to throw an old one away. Pretty sure it is in good shape, just tired of holding onto everything.
Shane
Hello,
Oh you have one you dont need? What color is it?
Thanks for the offer.
MrAl
Post by MrAl »
skloon wrote:I did this too had a hard time finding a good one at picknpull so I cut the back out a bad one and attached to my old one with epoxy and a couple of torx screws and some hidden aluminum to reinforce- better than new and you cant see that part unless the seats are reclined
Hi,
If i could see a picture of one that was fully intact, with latch too, then maybe i would know how to fix that too. If it comes to that i might do that also, with the epoxy. I already have a lot of that JB weld stuff, both the fast cure and slow cure. Obviously i had a lot of stuff to fix in the past :-)
(broke the plastic window off of a car battery charger ampere meter and did not want the needle to get damaged, so i had to construct a new one with plexiglass and epoxy for example).
skloon
Post by skloon »
I thought the latch was just a magnet
Post by erikv11 »
I wonder if I am wrong and the S/V70 doesn't have a latch, but something like a magnet as skloon suggests. I know the 850 has a latch because a few years ago I had to deal with the console breaking where the latch hooks to it. I will check my x70 cars tonight, see what I see too.
