Bad ignition coil?
- Been thanked: 4064 times
You should not be able to see any sparking from the ignition System, so a set of new plug wires ( Bougicoird brand) is in order to start. See if that fixes the coil first.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Wow. First of all, you shouldn't have to pop the hood after every drive to make sure there's no fire. If you feel like you do, then there's probably some steps you should take.
- Your coil should not be buzzing when the car's off - mine buzzes a bit when the engine's running, but I have to put my ear down to it to hear it. Also, what do you mean, "well lit up"?
- You should never see flashes of light (arcing) in the spark plug holes. See abscate's advice.
- You probably shouldn't be driving that thing around until coil and wires are fixed - also, check and see what that CEL is about - I've got 10 bucks on misfires.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
Darkskies65 wrote:And by "well lit up" I mean the coil was glowing with electricity. However, it was dark outside so maybe that's not an issue
Oh, and did I mention that you shouldn't drive that car until you change the coil? In fact, you should probably go outside and disconnect your battery right away.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
Well, anything visibly glowing where there's fuel and oil in the immediate vicinity is pretty serious.
That said, the most likely scenario is your coil letting go and simply melting into some goo and scorched metal, but you never know. There's dust, old leaves, old oil and whatnot, which is all to happy to burn given a few hundred degrees of glowing metal available.
In addition, uncontrolled arcing is also a fire hazard. So while you might just end up stranded, you could end up stranded and on fire, which is less desirable.
Changing the coil is a 10-minute job at the most, so there's really no excuse.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
Darkskies65 wrote:from the last time this engine caught fire
Jaysus... what happened?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 14 Replies
- 9103 Views
- 1667 Views
Last post by RickHaleParker
- 2375 Views
- 13 Replies
- 8850 Views
- 6145 Views
