Hi, so i just got my 2000 s80, first car, and i have a few questions
1. How do i get the trunk latch on the trunk to work
2. My passenger seat wont move
3.how do i get the button for the back head rest to work
4. Where is the clock????
Thats about it for now
Volvo s80
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
1. Check the fuse first. The trunk opens when you depress the switch just above the license plate with your fingers. It is either that switch or the relay for the switch. In my case it was the relay.
2. If the seat does not move with any of it`s switches, check fuse first. If OK then look under seat for the main power plug, check it`s connections and wires.
3. Check the fuse first. Then check relay.
4. in the instrument display at the bottom
Firstly, YES for S80 as a first car (same for me, a 2002)! Secondly, I always thought I had to pop the trunk with the fob button, but there's actually a little release button under the ledge above the license plate. Thirdly, yeah, the seat not moving is going to likely be an electrical/mechanical issue. Likely the same with the headrest. Fourthly, the clock is on the instrument panel with the temp display. The clock is a pain to set, so definitely consult with the manual for that.
As for the A/C, definitely make sure the A/C button is ON, haha! If it's still blowing warm air and never cooling, could be freon. If it's cooling weakly, then maybe an A/C recharge could help.
I probably repeated some of what's already been said...but oh well.
- 1297 Views
Last post by Volvo S80
- 738 Views
Last post by Synergychaz
- 784 Views
Last post by krassigr
- 1724 Views
Last post by BigCabrito
- 4708 Views
Last post by chieze1090
