Hello everyone! My last post was in the 850GLT section.
Today I am sharing the sequence that worked for me for resetting the Book service message.
First:
-It works with any miles in the trip odometer (mine was zero because I tried several methods and ended resetting both counters several times)
- It DOES NOT matters if your door is open or you are using the service key or your normal key (which is the same but without the remote)
- It DOES work either in Trip 1 or trip 2.
Second... the sequence.
-Turn the ignition key to position I
- Press the reset trip button (just press it and keep it pressed, time is not an issue as long as you continue the sequence)
- Turn the ignition key to position II while keeping the trip button pressed
- Watch for the triangle with the exclamation symbol, wait a few seconds and it will start blinking. When it has blinked three times (!!!) release it and immediately press ONCE the trip button.
- Turn ignition key to I and then to 0
The reminder should have been reset to zero.
Hope it works for you as it did for me.
See you around the forum!
Reset "Book service" message S80 2004
mynoralvarez
- Year and Model: 850 GLT 1995
- 8296 Views
Last post by BlackBart
- 1613 Views
Last post by elmwoodblues
- 10241 Views
Last post by natural4reelz
- 11277 Views
Last post by precopster
- 2583 Views
Last post by tbonehemms
