Tie rod end replacement
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Hi folks,
I took my car to the dealer for the yearly inspection, among some other small things, they told me I have to replace the right inner tierod end # 274353.
Now, I replaced the exact same part one year ago (TRW), therefore I am suspicious.
Also, they say I need wheel alignment ($90.00) which I also did last year for the same reason.
What do you suggest? I can certainly look at it myself ....
Is the wheel alignment really necessary?
As far as I am concerned, the steering wheel works perfectly, I feel no movement at all.
Thank you
Alex
Polar 940 Turbo SW - 1997
Has thanked: 1610 times
Been thanked: 4065 times
You should be able to replace an outer tie rod end and maintain front end alignment if it isn't too loose, but an inner is probably not going to seat exactly in the same place. They should last longer than a year.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
This is how I check the geometry to get an idea. It is not perfect, but the 'accuracy' is enough to keep uniform tire wear
Welcome also into the amazing world of terrible aftermarket replacement parts. I'd take a moment to check on this forum about which aftermarket parts are recommended and which not. As for TRW I just google it
http://ls1tech.com/forums/suspension-br ... -good.html
It is easy to look at the tire rod, grab it by hand and move to feel for play, or see if the small dust boot is ripped.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
vtl
Post by vtl »
You won't be able to get exact same toe-in after replacing tie rod end. Unless you have something like Trackace laser gauge (costs slightly more than alignment procedure at dealer, or maybe less, depending on where you are). Or if you dare to use fishing line and precise sub-millimeter ruler, though it's not easy on XC because of difference in front and rear track.
Trackace for front axle is perfect.
Metallo
Post by Metallo »
I will verify if the tie inner rod is gone, but the real question is: what to buy aftermarket?
I will check where the TRW I have comes from but really, I do not know what else to buy.
Who is Volvo OEM for tie rods?
Alex
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
I wouldn't`t be surprised if he heard a click in the are were the inner tie rod connects to the rack. It is the gear lash being taken up on the steering rack. Have someone turn the steering wheel 1/4 turn back and force and put your head down in that area to listen. Can`t remember if tires should be off the ground or not
