1988 Volvo 240 DL Wagon - $5500 (Newton, Kansas)
zimmerdale
Year and Model: 1996 855R
Post by zimmerdale »
http://wichita.craigslist.org/cto/5718868789.html
Lots of pictures: http://tinyurl.com/1988-Volvo-240
I'm sad to list my favorite Volvo wagon for sale, but it's time to thin the herd.
This 1988 Volvo 240 DL wagon was originally a Georgia car and was meticulously cared for by the Volvo dealer in Macon, Georgia. When I called the dealer a couple years ago and described the car, they remembered it immediately. It came to Kansas with a community college student in 2007 and was sold to an elderly man in Pratt, Kansas in 2009. I purchased the car from the gentleman's son after he was no longer able to drive.
Over the last couple years I have slowly fixed or replaced everything that I found that the car needed. The odometer didn't work when I purchased the car, which is a common problem with these older Volvos. I repaired the odometer and, using the Carfax records and the recollection of the former owner, reset the odometer to be close to the estimated actual mileage. This car is in excellent condition for its age. You would never know it has over 200k miles! The car has absolutely no rust anywhere.
Everything works as it should on this car. The one exception is the A/C, which blows cool, but not cold air. The old R-12 system was converted to R-134a and works properly, but it isn't as cold as a new A/C system.
The old tan interior plastic pieces are known to turn to breadcrumbs by this age. I've managed to find good quality replacements for everything that was broken or cracked. The exception is the dash, which does have a few cracks in it, as is common on older dashes. The driver seat bolster had a large hole worn in it, so I had an upholstery shop repair the seat. The patch is visible, but doesn't stand out.
The exterior is in very good condition. At some point, the original owner had the car repainted in the original metallic beige and finished with a high quality clear coat. There are a few chips in the front and some scratches in the finish, but overall the paint is still great. The passenger rear door has two small door dings, and the driver rear wheel arch has a small dent. If you look very closely, you can find one small hail dent on the roof.
I own and maintain five old Volvos. I pay attention to the details and fix all the little things that often plague the 240s, like straightening all the door handles and installing new stops, rebuilding the seat heaters, repairing the rear seat release handle, etc. I have also done extensive maintenance to this car and put on many new parts. I will include a full list below. I also keep lists of all the part numbers, brands, where I bought things, and prices, if you really want to geek out.
You are welcome to come look at the car, or I can assist with shipping (at the buyer's expense). I will accept payment in cash or by cashier's check only. No exceptions. Please look at the pictures and let me know if you have any questions.
Thanks for looking!
Jason
Parts/Repair list:
Engine
New distributor cap, rotor, spark plugs, spark plug wires
New engine accessory mounting bushings
New HD oil cap seal
New oil dipstick o-ring
New air filter thermostat
New motor mounts
New alternator, air conditioner, and power steering pump belts
New oil separator box, o-ring, and flame trap kit
New intake manifold gasket
New throttle body gasket
New vacuum elbows
New 3/8" vacuum hose from intake manifold to brake booster
New 3/8" return fuel line
New throttle position sensor o-ring
New injector seals
New air filter
New vacuum check valve (manifold to climate control)
New air intake hose (MAF sensor to throttle body)
New oil dipstick
New thermostat (87 degree Celsius)
New 0.75 Bar coolant reservoir cap
New coolant expansion tank
New water pump
Coolant flush
New timing belt
New timing belt tensioner
New front engine seals x3
Fluids
Engine oil: Mobil 1 10W30 High Mileage with 1 quart of Lucas Stop Leak (every 5k miles)
Transmission: Mobil 1 ATF
Coolant: Volvo OEM
Power Steering: Red Line 30404
Brake: DOT 4
Rear differential: Mobil 1 75W90
Exhaust
New muffler to muffler exhaust pipe
New tail pipe
Fuel
New fuel filter and seals
New fuel pre-pump kit: pre-pump, filter sock, fuel sender seal ring
New main fuel pump
New fuel pump relay
New fuel pressure regulator
New fuel pre-pump (warranty)
New fuel pump mounts
Mechanical
New wiper motor
New windshield washer pump (front)
New odometer gear and estimated mileage update
Power steering fluid flush
New washer reservoir cap
Lubricated rear hatch lock actuator
Brake fluid flush
New rear differential fluid
New differential cover gasket
Cleaned and painted differential cover
New ball joints
Transmission
New transmission filter and pan gasket
Transmission fluid flush - 10 quarts
New transmission mount
Electrical
New tailgate wiring harness right
New tailgate wiring harness left
New third brake light bulb
Two new license plate light bulbs
New shift indicator bulb
New rear hatch light bulb
Body
Reglued right headlight lens
New headlight bulbs
New front grill logo - domed poly
New right backup light lens
New (used) antenna retainer clip
New (used) front spoiler bolts and washers
New engine belly pan with new stainless steel bolts and washers
New window scrapers
New left headlight lens
Interior
New Rensi floor mats
New (used) passenger seat adjustment wheel
New sun visor clips
Replaced broken plastic interior bits
Rebuilt driver seat heater
New door pockets
New (used) interior b & c pillar trim
New (used) center console
Repaired rear seat latch handle
Driver seat vinyl professionally repaired
Carpets removed and washed
1996 855 R (red) 219k miles
1993 945 T (white) 207k miles
1993 244 (black) 264k miles
1992 244 (blue) 260k miles
1958 444 (jalopy)
kyk007
Year and Model: 1990 240 wagon
Post by kyk007 »
Is your 240 wagon still available? If so, I would be interested. Please PM me.
zimmerdale
No, sorry. It sold in 12 hours when I listed it on Ebay.
1958 444 (jalopy)
