Volvo 2005 S60 - Difficulty Starting (Unknown Part Needs Identification)
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
vorbosh
Year and Model: s60
Post by vorbosh »
I'm trying to troubleshoot an issue I have starting the car. The problem seems to be worse after the car has been sitting for a while especially when its hot outside.
Please ignore the (Unknown part needs Identification) in the title. I've replaced the brake booster vacuum switch. 5 coils and the fuel rail pressure sensor to no avail. No codes are popping up.
Has thanked: 1500 times
Been thanked: 3810 times
You need to confirm the fuel pressure at the rail at this point. Either a cheap tire pressure gauge or borrow a fuel pressure gauge from a parts store.
MarcM
Year and Model: 2005 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 3 times
Post by MarcM »
Volvos aren't the kind of cars to shotgun random parts at to diagnose, unless you have deep pockets and no dependents. ;)
Air, Fuel, Spark... start simple. Other than an internal mechanical failure (which would be usually heard), these are the places to always begin with. Spark and fuel are easiest and first places to start on a modern engine due to the air intake system having multiple failure points to investigate. You might be able to rent a fuel pressure kit from an auto parts store. If you weren't in Texas and over a 24hr straight ride away, I'd offer my MacTools Master Fuel Injection Test Kit (although it also does mechanical diaphragm pumps). I spent serious coin on the kit and should have just looked for someone who rented or had such a kit. Was young(er), single and dumb.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
Grooveman221
Year and Model: 2006 v70
Post by Grooveman221 »
Doesn't hurt to check this. You might get lucky
