Initial symptoms are restarting after a long drive it wouldn't restart right away if motor was still warm/hot. Then last night it dies out, I hook up fp gauge and no fuel pressure at key on. I swapped fp relay and nothing, I finally take my key outside to try to reset everything by locking and unlocking drivers door and fuel pump primes then it starts. Only difference now is a faint buzzing behind dash cluster area near climate control. It's a buzzing only an owner of this particular vehicle would hear. Never heard it before. I know some alarm immobilizer will let u crank ignition all day but cut off fuel. Some immobilizer won't let nothing happen. It will crank all day . Only weird thing is the car stalling out, I was thinking maybe two different issues like crank sensor/immobilizer but no CEL.
2000 V70XCse
Not sure on this one but something cutting off fuel
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
Does anyone know location of the immobilizer/relay?
I already swapped in a known good FP relay. I was thinking maybe crank sensor but I should a CEL.
This is a 2000 V70XCse with 160 on the odo.
I've also been getting poor gas mileage, only use it for city driving so not much hwy but 12mpg is kinda low.
- Been thanked: 4068 times
I think the ME7 immob turns off spark only.
You have fuel pump supply voltage or fuel pump problem. Confirm by watching the pressure at rail.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
try the following: have someone turn the ignition key to start while banging on the fuel tank with a piece of wood a few time really good. If it fires up it is definitely the fuel pump. If not it might still be as abscate suggested.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- shiloh51933
When it died there was no pressure at rail, even during key on the gauge doesn't move.abscate wrote:I think the ME7 immob turns off spark only.
On the wagons you have to drop fuel tank right, on the 850/S70 there was an access panel in trunk if I remember correctly and the hareness/plugs for fuel pump/sending unit. Do you know location of that stuff on the 2000 V70xc or do I have to crawl underneath the rear of car?
- shiloh51933
After further investigation this is what's going on. The front door actuators are triggering the immobilizer and in turn the immobilizer cuts off voltage to the fuel pump. I'm replacing the actuators in both front doors today and I'll post back my results after finishing installation.Clemens wrote:try the following: have someone turn the ignition key to start while banging on the fuel tank with a piece of wood a few time really good. If it fires up it is definitely the fuel pump. If not it might still be as abscate suggested.
When this issue first showed it's ugly face I thought security system malfunction after a couple of weeks of no start when trying to restart after a long drive. This no start symptom didn't happen every time trying to restart but when it happen I had been driving for a while. Then she actually cut off during operation and I was thinking possibly crank sensor. After testing for fuel at fuel rail I thought possible fuel pump or FP relay and swapped in good relay but no good. I reset the security system with key at L/F door lock and that worked initially but the actuators got worse.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The door locks have nothing to do with immobilizer. The alarm system will not power starter relay as its way to anti-theft the car but that would also be flashing the signals at all 4 corners on that car. Immobilizer reads key chip and fails to send key OK signal to engine computer.
When your fuel pump is failing the pump will often work randomly. You could convince yourself that peeing on the right rear tire twice makes it run due to a few start tries making the pump run on occasion.
- Has thanked: 311 times
- Been thanked: 817 times
jimmy57 wrote: ... You could convince yourself that peeing on the right rear tire twice makes it run due to a few start tries making the pump run on occasion.
I've definitely been there, done that, in one way or another ...
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
FWD V70s have an access panel as well. To replace the pump on an AWD or XC, you have to either cut an access hole in the cargo area floor or drop the fuel tank.shiloh51933 wrote: On the wagons you have to drop fuel tank right, on the 850/S70 there was an access panel in trunk if I remember correctly and the hareness/plugs for fuel pump/sending unit. Do you know location of that stuff on the 2000 V70xc or do I have to crawl underneath the rear of car?
- Been thanked: 504 times
I'd:
1. Jump the fuel relay (use proper jump wire, spade type ends and insert into 15 and 87 sockets).
2. Listen to fuel rail with screwdriver + ear (ear to the end of screwdriver).
If you hear fuel running, all it means is that there is fuel flow, but the pressure can only be checked with proper fuel gauge.
How many miles in your 2000 Wagon, I have the feeling your fuel pump is going South...
- 542 Views
Last post by martz
- 54 Replies
- 11091 Views
Last post by GreenMagicMan
- 559 Views
Last post by cn90
- 21 Replies
- 2548 Views
Last post by RedBrickCollector
- 13 Replies
- 2826 Views
Last post by plumsmooth
