Just completed a 500 mile mostly interstate round trip with my 93 850 GLT and achieved 32 MPG highway which I was very happy with. I get about 22 around town - is that consistent with others?
Also noticed that at times auto trans seemed reluctant to shift back into OD after going up a grade. I noticed that in OD at 70-75 mph, tach was around 2700-3000 RPM. When it seemed to stick in 3d gear, RPMs stayed around 4000. My tach works about half the time - seems accurate when it's working and just flops to 0 when it decides to take a nap.
Do my RPMs sound about right for 3d gear and OD? Does anyone know what might cause the trans to balk at going back into OD? I run it in "economy" mode all the time - never "sport" mode. Recently flushed trans fluid and replaced it and the fluid level is good. Also, trans seems fine in around town driving. Insight on my balky tachometer would also be welcome.
Thanks!
500 mile trip - impressive MPG and trans questions...
I've also got a '93 850glt and all my numbers are very consistant with what you list. I get about 32/33mpg traveling on the NYS Thruway at 70mph and in the low-20's around town. My tranny also seems to have a "difficult" time shifting into OD after going up a grade.
1993 Volvo 850glt
225,000 miles and counting
Thanks very much everyone - it helps to know that my numbers are in line with the typical 90's 850. I have one more question and it's probably kind of stupid - what is the "shift lock" function? I assume it keeps the transmission from upshifting when engaged? I have the little shiftlock button at the top right of the gear selector but I only use it to "unlock" the shifter so I can take it out of park (have not gotten around to replacing the little shift lock relay/switch thingy inside the console). Thanks again all.
Utvol, the shiftlock button unlocks the shifter. It is there incase the solenoid and switch fails that automatically unlocks the shifter when you step on the brake. To my knowledge it serves no other purpose. Had to have mine repared about a year or two ago.
BTW, my mileage and shift characteristics are identical to yours when in economy mode.
S
S
2007 XC70 21,000 Miles
1993 850GLT, bought new
133,500 Miles & 15 great years of service
Thanks Steve - good to know that my car behaves similar to most others out there of the same general year and mileage. Thanks for the tip on the shift lock also. Like I say I have had to use it continually since I've had the car. I have the replacement part to fix the shift-lock problem but just have not tackled that project yet. My car needed a lot of work when I bought it - mainly front suspension. I got that all fixed up tight and the AC issues resolved, now I'm moving on to smaller stuff and hopefully some body work.
- 5610 Views
Last post by jonesg
- 1138 Views
Last post by volvolugnut
- 1082 Views
Last post by pbierre
- 3763 Views
- 27 Replies
- 5192 Views
