So, we happened to back over a bump that ripped the front bumper off on the passenger side. Looks like the clip ripped when it happened. Is there a fix for this other then having to replace the entire front bumper cover? I tried to attach a couple pics to show the damage. This is my first post, so any help would be greatly appreciated...thanks!
2006 S60 front bumper
chrisbanks00
- Year and Model: 2006
JRL
- Year and Model: Several
- Been thanked: 16 times
Not really unless you can fab something up and epoxy it on
chrisbanks00
That was the answer I was unfortunately expecting.
neworleans
- Year and Model: 2007 S60R
There is plastic bumper support right behind it, you can drill a hole through the bumper and the support and bolt it. You can also paint the bolt if you want to make it look better. You will need to put the car on ramp I guess to access to the back of the support to hold the nut. The new bumper runs around 700 bucks or around 300 bucks if you find a used one, I don't think it is neccesary to spend this much money for this damage.
Here is a bolt I suggest.
http://www.directindustry.com/prod/4b-b ... 33335.html
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I don't see anything bad with it. You may have plastic plate broken, which is riveted to the wheel's arch plastic protection and bolted to the chassis, that thing is what usually brakes in such accidents. You can replace it. Bumper is held in place using rails on the plate and another retention plate in the front of wheel arc, which drives out with the screw and pulls the bumper's ends backwards.
- 1370 Views
Last post by mike:
- 1831 Views
Last post by Rattnalle
- 851 Views
Last post by JNavas
- 801 Views
Last post by projectPONY
- 4690 Views
