1996 855 N/A to Turbo conversion thread
jose456891
Year and Model: 850 GLT 2.4 1996
Post by jose456891 »
INB4: "Get a Turbo, it's expensive to add one to a N/A. :evil:
TL/DR: I'm making a list of upgrades before adding a turbo.
Here is the deal Gals and Gents. I've sunk enough money into my 96 855 N/A to confidently say that the suspension, brakes, interior, drive train, fuel and AC system are new or in better shape than late model cars.
So, selling my brick for a turbo version is out of the question. I've even lowered the suspension and I gotta say... wow ... this car handles better than any car I've driven before.
Money... let's be honest, I would not have started this thread with out having it. So don't hate on the conversion or this thread.
No I'm not planning to swap engines, or butcher the engine harness, or swapping heads to prevent the engine from exploding. Literally every one who recommends that on the other threads should be shot. The N/A is a perfect candidate to receive a turbo, even with its higher compression ratio. Research before speaking... I'll soot you otherwise 8)
List of upgrades before adding turbo:
Bottom end rebuild, upgraded rods
Motronic 4.4 upgrade, chipped with USB (DIY)
Auto box oil cooler in series with stock cooler + remote filter
Engine oil cooler
Air ram mod
970 throttle plate
Turbo accessories:
Japan turbo exhaust manifold
19T/20T turbo
Catback
Wideband O2 sensor
Turbo water pipe
Acessory Oil/Gas separator or oil condenser to stock separator
Upgraded injectors
Barometer mod (to ditch MAP)
Why??? Cuz I can
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Go big or go home.
85 GLH, 367 whp
00 Insight, 72 mpg
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Well hey, go for it. You sound like a man with a plan, a direction, and focused determination.
I look forward to reading about it!
Also -> Amazon link
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
I like this. I wanted to do this with the first 850 I had, and was shot down by all the usual comments. :) After an additional 2 850s and an S70, I've read several projects where adding a turbo to an NA has been done successfully - makes me almost want to try it again. Please post lots of pics and progress updates, just to rub it in the nay-sayers' faces! ;)
- S
[Sold] '97 S70 T5
RigsPGT
Year and Model: Red 99 S70 T5,
Been thanked: 2 times
Post by RigsPGT »
As long as you take care of tuning, higher compression helps you spin tires and make more power with lower psi. One thing I don't get is, why would you mod an NA to its teeth then go big at the end? Perhaps you didn't have the money at that time for a turbo one and now you hit gold or smth? Not hating on your idea as I've done it many years ago on a different platform that didn't come with turbo option but I don't like all the cockiness in a forum where you come to find answers and hopefully help others in return.
Again, not trying to be a naysayer as I've always been on the edge to try new things but the delivery kinda ticked me off! Oh and if your Volvo handles better than any car you've driven, well I'll have to say you've driven wrong cars or cars that are not meant to be driven that way.
Good luck with your project and enjoy the WOW effect that the snails provide!
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
You need to tap an oil feed port for the turbo somewhere on the block. On Volvo turbos that spot is high up on the block right near the rear of the water pump. There is a blank area on a rounded boss.
Tapping an M10 thread in there is hard going without removing the engine but of course you can do it.
