98 V70 control arms - sub frame bolt orientation Topic is solved
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
I know that it probably doesn't matter much but for the two bolt control arms which way are the bolts supposed to go in...nuts forward, nuts aft or some other orientation? I've taken the control arms loose at the subframe once before and didn't pay attention when I took them off.
- Has thanked: 2200 times
I have always fitted the nuts to the rear and Vida shows the bolts fitted from the front and nuts from the rear (although that is not always a 100% proof of point as I have found in the past). I have always done this on the -98 P80's with the 2 bolt control arms. I can't honestly think why it would make a difference as the bolt is only a pivot, but I've just followed convention!
The only complicating issue I can think of is to make sure the tire clears the hardware on full lock both ways.
We had a debate on strut bolt/nut placement and it turned out my original struts on the 1999 were bolted differently left/right!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Something worth considering:
When a car is moving forward, which end do the bugs collect on?
If a bolt head gets covered with crud, it's no big deal.
When a nut and exposed bolt threads get coated with
road debris, it's more of a PITA to get apart. Just sayin'.
I love to hear when others have successes after being frustrated trying to find the weird cause of a problem. It is always very satisfying when you get something like that figured out. So what next......, a long holiday somewhere warm with a few refreshments to get away from Volvo repairs!!
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Great news!98v70dad wrote:Installed the the new control arms this morning .... nuts aft. So be it! The new control arms completely fixed my jiggling down the road at 65 to 75 mph. Hurray!
Cheers & Beers to celebrate!
M1 10W-30 HM
M1 10W-30 HM
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
In a wheel well, does the crud come only from the front? I'm not sure that the direction of travel is the major influence on road-derived garbage in the wheel well.BEJinFbk wrote:Something worth considering:
But I agree that the best orientation is probably the one that's easiest to remove fifteen years down the line.
98v70dad
Installed all of them nuts aft. As I initially indicated I don't see why it would matter much. I. too, thought about the crud from the front. For me it was more of an issue of fitting the wrenches I have in around all of the obstructions in the wheel well. Aft worked best for me.
