Hello all,
I'm looking for a little help. What I have is a 2001 XC70 with a start prevented try again in the DIM. Here is the story on its origin. R&R'ed the PCV and complete timing belt replacement with H2O pump. While working on this car, it's belongs to my lady, I was hearing a little fan blower sound when inside the cabin. After I has assembled front of engine and rotated engine to double check my work, the battery was down. I was thinking that maybe doors left open with a 48 month old battery. Recharged and cranked up, ran good like a Volvo should. Next morning battery was dead. I disconnected the little fan on the backside of the ECC module. Charged battery and once again battery died over night. Battery checked out good. Checked amp draw, pulling some current with everything off with my lady crammed in the back with the hatch down. Was a lovely sight with that look on her face. Anyways we got into the front of the cabin and interior lights acted really strange, but would eventually go off. However the ignition key bezel light stayed lite. OK, she needs car running for work and I don't have an extension cord long enough to follow her around for the charger. Sooo I decide to remove bulb from bezel until I can discover the true cause of light staying lit. While it was apart I could crank up the car. Now that it doesn't have parts laying on floor I get the Start Prevented Try Again. What have I done??
That warning is part of the anti theft system, the antenna ring that communicates with the chipped key is right around the ignition ( the area that you worked on). Did you leave it unplugged or damage it? This problem came up on mine when my old starter battery's voltage was low and would not charge fully. The best way to find a parasitic power draw is to use a volt meter set on amps and put it in series with negative battery terminal and if the draw is over 50 Ma (rule of thumb) start pulling fuses until you find the drain.
Thanks
Will remember the fuse pulling the next time I try to locate a current draw. The antenna ring? Is that in the small module that hangs around the key hole with a small harness connector with about 6 to 8 wires? And if so, do you know the continuity reading on it? Mine is showing a high reading, but not an open.
- Been thanked: 4064 times
That bulb might be in series with some part of the antenna ring immobiliser circuit so I would put it back
The 1999 on climate system does turn the fan on after shot down to keep the evaporator from corroding, so fan noise after shutting off is not necessarily a problem
- 13 Replies
- 12205 Views
Last post by SVO LOU
- 3085 Views
Last post by maleekberry
- 1095 Views
Last post by Volvo S80
- 22 Replies
- 2953 Views
- 898 Views
Last post by 02V70
