Hello,
When I first purchased my Volvo 850, I set about replacing the speakers throughout with spares I had sitting around. I haphazardly installed larger than stock 6x9 speakers in the plastic enclosures, which worked well enough for nearly two years. Recently, I've noticed a distinct rattle in the rear deck, and upon investigation, both of the plastic enclosures have cracked due to stress from bumps and the larger than stock speakers installed.
I'm wondering, has anyone has removed the plastic enclosures completely, and mounted the speakers to the deck directly with any success? I'd like to eliminate the rattle if possible, and continue to use the speakers I already have. Any advice is appreciated, and if needed, I can snap a few pictures of the damaged plastic enclosures.
Advice needed for rear deck speaker rattle
- dorvin
- Year and Model: 1997 Volvo 850 T-5
- Has thanked: 1 time
- Been thanked: 4 times
I don't know if this is allowed, but, bump. Please, any advice or tutorials that exist would be greatly appreciated. I searched, but only came across guides for S70s.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I mounted 6x9s using a plywood spacer plate. Has been working like a charm for 6 years. I even managed to put the original grill over them. Bolting the speaker directly to the deck should work fine, just put felt or foam between the deck amd the speaker
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- dorvin
Hi Clemens, is there anyway I could see a picture of your setup? I know you have a wagon, but just for a visual reference.Clemens wrote:I mounted 6x9s using a plywood spacer plate. Has been working like a charm for 6 years. I even managed to put the original grill over them. Bolting the speaker directly to the deck should work fine, just put felt or foam between the deck amd the speaker
- Clemens
It is on my wifes sedan. I'll try to take a picture tomorrow.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
Dorvin, sorry, i was swamped at work this week. I tried to take a photo but it is useless because it only shows the rear speaker cover raised by a few mm above the original speaker bracket, the gap masked with black tape.
i think how I did it was that i pulled the whole speaker assembly, removed the cover, made a plywood bracket with the same size as the speaker cover where I cut the hole for the speaker out (the box of my Bostons had a template for cutting and drilling the correct holes). Then I screwed the speaker onto the plywood spacer, screwed the spacer to the old speaker mount and fixed the speaker cover with black tape. Took me about an hour or so. Very easy to do.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 3170 Views
- 793 Views
Last post by mike69
- 3427 Views
Last post by callahanoffroad
- 2205 Views
Last post by tsteph99
- 1024 Views
Last post by MoVolvos
