Intake banjo bolt
Greg2545
Year and Model: 2000 v70xc
Post by Greg2545 »
I have spent the past 2 hours trying to install the banjo bolt to my intake from the top of the engine, a blind or by feel job everything is attached except this bolt and tightening the manifold. Pleas help with suggestions. 2002 Volvo S60 2.4 T3
Thanks
Greg
Greg2545
Post by Greg2545 »
Well I broke down and took the p/s pump loose and moved the alternator to get to a place where I could get my grubby paws to the banjo bolt
SUCCESS!
Has thanked: 1610 times
Been thanked: 4065 times
That's a brutal one, indeed.
I installed it on the manifold before I installed the manifold onto the car after fighting it for 30 minutes
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Yeah just did this on my 2001 T5 last week.
I didn't screw the manifold down; only had the bottom bolts for the manifold on the head and had the PS pump removed. Also removed the cooling hose from the thermostat housing then when I had 3 turns on the banjo bolt I connected the cooling hose then hung the manifold properly. It was still difficult and I dropped the bolt twice.
