KONI FSD?
srnkanator
- Year and Model:
anybody put these in? I'm wondering what they are like . . .
After 4years of driving with bilsteins HD, i had it with the HARSH ride. Took a chance and went with the Koni FSDs to replace the bilsteins.
I've had them on my C70 for about a month....they are truly amazing.
Its the best of both worlds....handling and comfort
At high speeds on uneven roads they give u soft damping....on bumpy roads at lower speeds they give u firm damping....the double valving is always adjusting the damping to the road surface.
Theres no other suspension system that can do that
Not bilsteins, not koni yellow adjustable, not any coilovers, etc.
Well worth the money
2000 C70 LPT ragtop with lots of mods.
srnkanator
- Year and Model:
what did you pay? I saw them online for $600 from paragon in corpus christi . . . IPD wants $800 plus shipping . . . what gives?
srnkanator
- Year and Model:
Thanks! I'll look into them
slightly modded 850 T.... ;0
2010 XC60 T6 AWD
2005 S60 2.5 T
2010 XC60 T6 AWD
2005 S60 2.5 T
srnkanator
- Year and Model:
I know that changing the springs to eibach will be much stiffer than stock. I've never heard of H&R's though. My 850 turbo's ride is so hornery though I think any suspension upgrade would be an improvement. Just putting in IPD sway bars has significantly improved the ride (less jerking over bumps). I live in Houston, TX where the roads are as smooth as a seventh graders pick up lines at his first dance so I'm worried about comfort and handling.
2010 XC60 T6 AWD
2005 S60 2.5 T
2010 XC60 T6 AWD
2005 S60 2.5 T
the underlord
- Year and Model:
FSD's are not to be used with lowering springs, AFAIK.
Koni state on there lit that there fsd's can be used with springs lowering up to 30/35mm. a lot of us in the uk have fsd's with ebach @30mm lowered and they are magic
S70 T5 CD '98 RICA'd 310. 302mm F/Discs. s/s hoses. F/strut brace. Koni FSDs Eibach 30mm lower springs.17inch comets. R front bumper. egg box grill, 6 changer cd, aerial down switch. k&n filter.polybushed control arm bushes & top engine mount.
- 3049 Views
Last post by shaker_chi
- 1871 Views
Last post by j-dawg
- 1179 Views
Last post by mika
- 6145 Views
Last post by mika
- 4990 Views
Last post by oragex
