EL. POWER SYSTEM SERVICE REQUIRED with new alternator Topic is solved
altalake
Year and Model: 2004 XC70
Been thanked: 4 times
Post by altalake »
Just replaced the alternator in 2001 V70 T5 - 140A unit - with an AC Delco rebuild. I know, I know, it's not a Bosch, but it's all that was available. It seems to work fine except, when I start the car, the DIM flashes the warning EL.SYSTEM SERVICE REQUIRED. When I say flash, it displays for about 1/4 second - but every time I start it. Cause for concern? Does something need to be reset with VIDA? Throwing the Delco away and buying a rebuilt Bosch for $600 is not an option.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Another Delco with a properly working voltage regulator is a possibility. The CEM is not liking the signal on the wire from voltage regulator. It can charge battery correctly and not have a VR that is OK for the circuit. The alternator may have the 2005 and up VR in it and could have been wrongly boxed.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I don't think it's a good idea in these electrical sensitive cars to have a so-so regulator
as above, the aftermarket regulators they put on rebuild alternators are *** Try getting a used original regulator out of ebay or scrap yard
Has thanked: 1610 times
Been thanked: 4070 times
I had my original ALT rebuilt for $200 on my 1999, as another option.
altalake
Post by altalake »
Thanks for the tips. Rebuilding wasn't an option in my case because the housing was cracked. There's also no rebuilder close by. I see IPD has the right Bosch regulator/brush set for $46USD (25% of the cost of the same thing locally) so I might just get that and put it in. The housing on this AC Delco rebuild appears to be an actual Bosch (or an exact copy) so it should fit. Sound reasonable?
oragex
Post by oragex »
They should fit, I believe. Also, if you didn't discard the old alternator, maybe just pull the regulator from it
altalake
Post by altalake »
Finally got a genuine Bosch regulator (new) and swapped it out (almost as much trouble as removing the alternator) and it worked. No more warning signal.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Regulator on the Delco probably worked, but was the wrong type. Two versions: one is old school voltage 'light' signal, the other is a data connection to the CEM aka 'LIN'. Aftermarket parts are known to get the interchange wrong for specific years/models. I believe either will technically work/power the electrical system and charge the battery, but if the wrong one is installed for the vehicle configuration you'll get a charge system MIL light and/or warning message on the DIM.
