Recently I became a proud owner of a '95 black sedan T-5R with automatic transmission in the Netherlands. Like all other 850's the odometer is broken and got stuck at 230,000km (±180,000 miles), probably 7 years ago, so it might have done a few more.. It is fitted with silicone pressure hoses, an aluminium intercooler and it is supposed to be chip tuned (don't know by who, or what). For the rest it is original.
Upon test driving the car, it hesitated on full throttle, around 3000 rpm. Reducing the amount of throttle would reduce the hesitation, but it then wouldn't really accelerate much more. I figured it had been standing still for a long time, so that could be it, but after I bought it and drove it for longer, the problem still exists..
I have seen the problem coming up on this, and other forums, but I never came across the answer to the problem. So hopefully you guys can help me??
I installed an aftermarket boost pressure gauge, which shows an increase in boost pressure up until 0.45 bar/±6.5 PSI (isn't this supposed to be 0.9 bar/12 PSI?), after which the hesitation begins. This is a quite rapid alternation of power on/power off, at which I can see the boost pressure drop a little bit and come right up again. Holding WOT will keep it in this mode, even after it shifts to next gear. I also placed some LEDs on the ignition and it looks like the ignition is slowed down as well, but I have to film that in slow-mo next to the boost gauge to be certain of that.
What I have done and done and tested so far:
full stage 0, incl. distribution, OEM turbo sparkplugs, distributor cap and oil/fuel filter. I also filled it with an injector cleaner and oil cleaner, to clean the insights.
I checked al vacuum lines and they seem allright
I unplugged the MAF, turbo control valve, waste-gate, blow off valve, different vacuum lines to see what that did: all of them had other issues come up, next to the hesitation. Also when I unplugged the waste-gate (the actuator), boost pressure came up easily to 1 bar, but the hesitation would still come in (I didn't let the boost go past 1 bar..
All codes checked in the beginning: it gave codes for MAF, auto transmission short-cut, brake-lights short cut, ABS malfunction and TRACS malfunction. Clearing the codes didn't change a thing and the codes didn't come back, so there is no codes now.
I fueled it with octane 102 fuel, but this didn't do anything to the problem.
Blocking the fuel reverse line didn't change anything, so I assume fuel pressure is ok.
Upon testing, the TRACS doesn't work and doesn't show any warning lights when the wheels are spinning and the cruise-control doesn't work. ABS works. I am not sure if this has anything to do with the problem, but I thought it might be of interest.
You see I am hitting a wall now in possibilities.. It seems that the problem is in the engine management, as it doesn't react on any of the hardware taken off. But I figure the ECU gets information from somewhere which isn't right. The question now is: what is giving the false input??
I am hoping somebody here can help me to find the problem. But since I have seen this problem coming up multiple times here, I guess it must be findable and fixable.
Many thanks in advance!!
