93 850 fuel tank leak
Larva
Year and Model: 1993 850
Post by Larva »
I've read may entries about the 850 series leaking when topping off the fuel tank. Well mine is doing that same thing. I thought it might be the vent hose that so many have well documented. Today I dropped the tank and replace the vent hose but the old one showed no signs of cracks or leaking. I don't know where to look next other than to fill the tank and look for leaks while I have the pump cover off. Further, does anyone know the best way to reinstall the rubber around the filler neck at the gas cap? I took the snap ring off and now cannot get it back together. Advice is appreciated.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
There was a recall on the part that separates the fill pipe to the tank and free replacement from the dealer. Of course your car might be to old but it's worth a call to the dealer with your #VIN
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Also...check connections/hoses on top of fuel pump assembly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Larva
Post by Larva »
I had checked with the dealer years ago for outstanding recalls/TSB for my car. As I recall, the fuel tank recall was for a heat shield. I was avoiding filling the tank because the fuel smelled up my garage but I'm thinking now that may be the only way to find the leak. Any advice on hoe to reinstall the filler neck rubber at the gas cap? I took the snap ring off to lower the tank and now cant figure out how it goes back on.
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
All fuel leak issues are consolidated into 1 thread below.
See the post from 27 Nov 2013. Take your time to go through all the links!
https://www.matthewsvolvosite.com/forums ... =1&t=60269
Larva
Post by Larva »
Thanks cn90
