Growling / humming sound while driving, 98 s90 please help!
Nathan007
Year and Model: 1998 s90
Post by Nathan007 »
Hello Folks! This is my first post on this forum.
I own a 1998 Volvo S90 with about 225 000km, i noticed a while ago a humming/growling sound while driving and assumed my messed up tires were the culprit, or worst case i had a wheel bearin slowly going.
I get a kind of humming , even slightly growling sound when i drive, starts at about 30 km/h and really becomes loud at 40-50 km/h, and will be overshadowed by windnoise and tire noise... I do feel a slight rapid pulse vibration coming from the whole floor at highway speed (100km/h).
My mechanic and i checked the car on a lift, i do have a very slightly worn rear right wheel bearing (slightly noisy but not loose), and he detected some noise coming from the diff pinion area (where the driveshaft enters the diff). No loose in the driveshaft.
Any clue what it could be??
Note; wheel bearings are originals, driveshaft ujoints/support/bearing, everything is original.. I do now want to spend a fortune on a car i paid 2 grand 3 years ago, but i dont want to destroy it neither..
Any imput will be appreciated!!
s10lowrider1994
Year and Model: 2000 v70
Been thanked: 3 times
Post by s10lowrider1994 »
Does it stop if you put the car in neutral?
Jeff Schubert
Year and Model: 1989 740gl
Post by Jeff Schubert »
Does it improve as you are going around sweeping corners? Ive found front wheel bearings that growl, that will get quiet going around corners. Not like stoplight/intersection corners, but back country type, long windy corners. Depending on the direction of turn, should indicate which side is failing.
Maybe next time after you drive it, check near the wheel hubs to see if they are hot. Bad bearings can get extremely HOT, so proceed with safety in mind.
Hope that helped, good luck!
1989 Volvo 740gl
1956 Ford F-100 Big Window
2006 Honda Shadow Saber 1100
Volvo2009
Year and Model: 1996 960
Post by Volvo2009 »
I hear same noise from my 960 (1996) while driving on highway. Noise increases with higher rpm, and decrease on low one. I suspect it has to do with the fuel pump.
The car has 236,000 km (146K miles)
Volvo2009
Post by Volvo2009 »
s10lowrider1994 wrote:Does it stop if you put the car in neutral?
In my case, no it does not. Only when I reduce speed (and rpm) the noise seem to subside.
