Steering column replacement
yamaboosh
Year and Model: 1995 850 GLT
Post by yamaboosh »
Hello everyone,
About 3 months ago I bought my first Volvo, a 1995 850 GLT. Two days in, the the key wouldn't turn in the ignition at all, so I had the car towed to a shop. The mechanic kept it for three days, and came up with a solution which cost me $600.
The solution at the time was to drill the whole column out and to start the car with a screwdriver. While a good temporary measure, it's becoming more worrisome as I've been driving it for almost three months now and it is extremely easy to steal. The mechanic tells me that I'd need to replace the whole steering column, which would cost about $600, so I am researching ways to do it myself with parts off the internet (±$150 for the column).
So, the question is: has anyone here done a steering column replacement? Is it doable for a non-professional? Or should I just save some money and have the mechanic do it? Any advice is appreciated.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I don't see why you would have to replace the column- most likely just the key tumbler (it's all a solid piece of aluminum)...it's like $250 at the dealer and with your model, the "keying" to your other keys from the VIN isn't going to break you. I can't believe he charged you $600 for what he did which was probably just remove the keying section of the tumbler. I have replaced the whole mechanism (tumbler) myself on my S70 a few years ago and posted pictures of it. Let me see if I can find that thread.
A video by our resident, Robert.
In this video he doesn't remove the entire tumbler. what I suspect is that your mechanic just removed the other side (the section the key fits in) and then which would then allow you to insert a screw driver to turn the ignition switch- in other words, he removed the "pin" that gets inserted into the electrical portion when you insert your key.
Here is the long thread on the ignition tumbler removal and replacement (it's the same on 850's)...Maybe you were using the wrong terms- it's not the whole column replacement that you might need.
viewtopic.php?t=34472
Btw, these cars are not hard to steal if someone knows what they're doing... if the section for the screwdriver is not easily visible from an outside window, and knowing the age of your car, I might not worry about all of this- just my opinion.
Read this too- could save you $$ if this is your issue (and your keyed tumbler section back in? Well, depending on how your mechanic "fixed" your ignition.
https://www.matthewsvolvosite.com/forums ... =1&t=67531
yamaboosh
Post by yamaboosh »
Thank you for your reply! I have here the document from the mechanic, here's what he did:
"Rear console, rear parts of steering column, drilled out lock cylinder, traced down broken upper column, drilled out steering lock, reassembled as needed. *notice steering column replacement est. $500-600"
I do recall him showing me the busted upper column with a piece broken off - that pin which you mentioned. (that'd be the reason why the steering wheel and the gear shift were locked dead (in case you ask, I did try the shift lock release button :P))
Has thanked: 1609 times
Been thanked: 4064 times
Just lock your doors and buy a Club or put in a kill switch. It would be crazy to put in a new column.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I think the O.P. meant "new tumbler".
Nobody replaces the steering column during the life of the car, unheard of, unless it is 1 in a million cases.
O.P., did you look at the FREE Fix posted above?
yamaboosh
Post by yamaboosh »
cn90, yes I did, but remember, I don't have the tumbler now. I'll still have to get a new one, supposedly, to use a key properly.
I will take some pictures of what's there and show y'all.
Post by cn90 »
Post some photos...
This whole thing could have been very very easy by removing the bottom plate and done with.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I'll try to make a good video Thursday. I'm taking an 850 apart. I'll pull the ignition.
