1999 V70 XC AWD 2.4T
Whenever I put it in reverse and it is turning I get a pop from somewhere under/toward the rear seats. I don't have any easy way of getting the car in the air at the moment. The AWD is working, but I think I smelled a little gear oil last time it was in use - need to check all the seals. It doesn't sound like a tire rubbing or anything.
Any rough ideas as to what I should check and where the next time I can get it off the ground that would likely cause a single pop? It only happens while backing and is always repeatable while turning...
Pop while backing in rear - only once and only while turning Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
I used to get a weird pop every now and then from the parking brake. I stopped using it and the noise stopped. But our car isn't an XC.
Retired:
2015 Volvo S60, T5, 85K
- wizechatmgr
Thanks, I'll give that a peektheWIFES_S70 wrote:I used to get a weird pop every now and then from the parking brake. I stopped using it and the noise stopped. But our car isn't an XC.
- wizechatmgr
Seems you were spot ontheWIFES_S70 wrote:I used to get a weird pop every now and then from the parking brake. I stopped using it and the noise stopped. But our car isn't an XC.
- theWIFES_S70
Glad we could help you troubleshoot this!wizechatmgr wrote:Seems you were spot ontheWIFES_S70 wrote:I used to get a weird pop every now and then from the parking brake. I stopped using it and the noise stopped. But our car isn't an XC.
I have the typical breaks in the rubber housing surrounding my parking brake and bought new parking brake cables but have been so lazy to replace them! I hear they're a bear of a job... I think I'll replace them when I swap out my rear endlinks this Spring...
Retired:
- Been thanked: 4063 times
Suspension work in Spring....chuckles....
- 1153 Views
- 741 Views
Last post by RickHaleParker
- 781 Views
Last post by tincanman
- 16 Replies
- 1993 Views
Last post by Camaro737
- 1204 Views
Last post by 06blue25
