On my '95 850 Turbo Sedan, I have a set of braided stainless steel brake lines that have been installed for ~12 years and ~150k miles. If they were the regular rubber lines I'd be thinking about replacing them due to age. I'm pondering if I should do the same for these, or if they will last for a long time to come. My best guess is that they came from ipd when I put them on. What do you think?
Roger
Life of braided steel brake lines
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Unless there's corrosion or any sign of damage, I bet they'll outlast the car.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Been thanked: 504 times
If there is any rubber crack, it is hidden by the braided steel.
The stock rubber hose easily lasts some 15y/140K or so, and any crack is visible to the naked eyes.
- Has thanked: 311 times
- Been thanked: 817 times
I think you're going to want to hear from someone who has actually used braided lines for a while. I haven't but I will also chime in with a guess.
The rubber hoses, when they crack, it is the outer sheathing that cracks. Even then, the inner liner is a separate tube and is basically never cracked. Use cracks in the outer layer as a warning - it's not an emergency, just an indicator to change them. On my cars I have had to change a lot of rubber lines, if I do it when the first cracks show up then the Volvo or ATE lines are probably lasting about 6 years. It will of course vary a lot with driving habits, e.g. freeway miles will have little effect on longevity. Anyway, the stainless lines also have an inner liner and an outer rubber sheath, plus the braided steel is a third layer that spreads the stress of flexing across more hose and provides a pressure jacket. It's the flexing that leads to cracks, from turning the steering back and forth.
I'd agree with Ed - run 'em with confidence but check them for any signs of brake fluid leakage, since you can't see any cracks in the outer rubber through the steel braids. They also aren't very expensive, when you consider how long they last, so maybe replace them on their 15 year anniversary, that would be a very long life for a brake hose!
- Roger_850T
I remember when I bought them, they were a pretty "high end" product. These days they seem to be pretty cheap. Part of me wants to replace them for peace of mind, and part of me fears taking off a quality part (albeit used) and replacing it with a new, inferior one. I've been burned with inferior parts too many times - if I'm going to bother to do the job, I'll put on good parts. But I can't find anything other than the cheap ones! <sigh.>
If waiting until I see seepage is a good method then ok. I'm more paranoid that I'm going to blow one out when I'm at 70+ on the Interstate and traffic comes to a sudden, screeching halt, with the expected disastrous conclusion. (And yes, that is my daily commute - 70+, with random, screeching halts for unknown reasons...)
Roger
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
When brakes fail, insurance kicks in. lolRoger_850T wrote: If waiting until I see seepage is a good method then ok. I'm more paranoid that I'm going to blow one out when I'm at 70+ on the Interstate and traffic comes to a sudden, screeching halt, with the expected disastrous conclusion. (And yes, that is my daily commute - 70+, with random, screeching halts for unknown reasons...)
Roger
Brakes are over rated. I like going forward.
- Been thanked: 4064 times
Old thread alert
Just noting that I’ve never had to replace brake lines on any of my cars. I’m pretty religious on my brake fluid changes, watching it run into my front wheel bearings
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Not even the rubber ones? None? On all the countless p80s you've hoarded?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
None - I do live in a mild climate with respect to ozone and sun - rubber parts last a long time here.
I dont keep brake fluid in them for more than 2 years - Hmmmmmmm
configsys
- Year and Model: V70R
- Has thanked: 2 times
- Been thanked: 5 times
Just had mine replaced at 215K miles. It had a few hairline cracks on the outer sheath but gosh after 20 years, it was time and I did go with the stainless steel braid ones.
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
- 1276 Views
Last post by jonesg
- 4150 Views
Last post by GreenMagicMan
- 12 Replies
- 3395 Views
- 1614 Views
Last post by moonweasel
- 3603 Views
Last post by db130
