New MAF, black smoke and stalling.
Moppman
Year and Model: 98 S70 GLT
Post by Moppman »
Alright, so I'm a first time Volvo owner. I bought this 98' S70 GLT for $2K in perfect condition with 123,XXX miles and was serviced regularyly until 75K. When I bought it, it ran fine but I noticed the MAF was disconnected and looked odd. Tried to plug it in and the car wouldn't idle longer than a few seconds and you couldn't hit the gas at all. So I left it unplugged. The car ran fine without it for the last 2 weeks while I waited for the new MAF, the default values kept it running smooth but was getting awful mpg (12ish). So I replaced the MAF then cleared the ECU by holding the terminals together for about 10 seconds. I started it up and now it idles but very roughly, also has some form of surge. Sounds similar to a cammed car and stalls as soon as you hit the gas. There's quite a bit of black smoke coming out indicating it running rich. I've looked all over and can't find any disconnected hoses, besides the very front of the intake which is behind the grill and looks like it should be connected to something but not sure. So it seems in the end I'm having a problem running way too rich. I have an OBD scanner coming in the morning so I can test the O2 sensor. Would really appreciate any help.
Has thanked: 1505 times
Been thanked: 3818 times
There are probably several things to put right, so lets start with
Cap Rotor plugs wires
Idel Air control valve - probably needs cleaning
Thats a turbo car, right? If there is the slightest leak in the induction hoses, after MAF but before throttle body, it won't run well with the MAF connected.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
The most important thing is ......is replacement MAF oem Bosch 0 280 217 107 or something aftermarket?
Is check engine light ON and if it is,what are the codes?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Moppman wrote:... the very front of the intake which is behind the grill and looks like it should be connected to something but not sure...
Just to confirm, this is not an issue, since this part of the intake is before the MAF.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
RigsPGT
Year and Model: Red 99 S70 T5,
Been thanked: 2 times
Post by RigsPGT »
Did you get an NA MAF or a turbo one? I'd rather trust a used OEM unit than a no name cheap eBay one so if that's the case, get another one asap. Basically your problem started happening right after installing the new one, have you tried unplugging this new MAF? I drove for 3k miles on my 98 NA with the sensor unplugged and that's why you found yours disconnected as the car still runs although not in optimal conditions.
Codes?
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
Post by erikv11 »
I agree, basically every used MAF at the junkyard is totally fine. Just make sure it is Bosch.
RigsPGT wrote:Did you get an NA MAF or a turbo one? ...
They are the exact same part.
'06 S60 R, 197k
Moppman
Post by Moppman »
misha wrote:The most important thing is ......is replacement MAF oem Bosch 0 280 217 107 or something aftermarket?
Nope, it's an OEM Bosch and no check engine lights when connected, only service light.
Moppman
Post by Moppman »
abscate wrote:There are probably several things to put right, so lets start with
Well, when the MAF is disconnected it runs fine so not sure about the rotor, cap, plugs or wires. Not sure about the leak before or after the turbo but will check. No obvious sign of one but I'll crawl under it tomorrow and have a better look.
Moppman
Post by Moppman »
Didn't think so, just odd that it's randomly placed and not connected to anything.
Moppman
Post by Moppman »
RigsPGT wrote:Did you get an NA MAF or a turbo one? I'd rather trust a used OEM unit than a no name cheap eBay one so if that's the case, get another one asap. Basically your problem started happening right after installing the new one, have you tried unplugging this new MAF? I drove for 3k miles on my 98 NA with the sensor unplugged and that's why you found yours disconnected as the car still runs although not in optimal conditions.
Codes?
With the old one connected it runs worse. Will not even maintain an idle. With the new one it'll idle but is just very rich with black smoke and giving any gas stalls it. It is authentic. No codes when connected, only when unplugged which is obvious and runs fantastic unplugged just bad mpg and not optimal power.
