Single noisy lifter.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
After a valve job (I think). 2k mile after the work, seems quite evident when cold, goes away after 3-4 minutes of idle. Using 10w-30 synthetic, Pennzoil Platinum. Can't recall hearing this much before the valve work was done. Never done any seals in the oil pan, 200+k miles or so on motor. Suggestions? I'm pretty sure it's one lifter making the noise, not several.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Have you checked/verified proper oil pressure with a gauge? Was the oil and filter a different brand/weight than what you were used to using?
What prompted the valve job?
Any idea which cylinder?
rguzz
Haven't verified oil pressure. Mann filter. #3 valve burned, zero compression. 3 valves total replaced, though. Was using 10w-40 Mobil 1, switched to 10-30 as above. Weather is mild here this year, so thicker oil could be used. I suppose could be pick up tube 0 ring issue, etc. Again, sounds like one lifter clack, somewhere near the front of the motor. Gone after 3 minutes or so at idle, sooner if I drive off right away. Oil pressure check next, then?
Was going on a 2,000 mile trip in 24 hours? Still okay? Once warmed up, runs like a top and quiet, no oil use, up to snuff.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Since the noise is gone when the engine is warm, I would say it's safe to drive.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
rguzz
Thanks. Will take it by the shop on the way out of town. Gone again today but it took almost 15 minutes! for it to go away. I'm guessing they might not have marked the lifters too carefully, and one or more were installed in a different direction than when removed. I doubt changing oil viscosity will do anything? Anyway, this is new since the rebuild, so I will ask them to reproduce it (cold start up) and address the options. It is loud enough to be annoying, especially after an upper motor rebuild. Lifters were not replaced, which I gather is the norm in these cars.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
On a '96 I don't really worry about lifter placement since they are hydraulic. It's possible that one is going bad. Hopefully they didn't use to much sealant when installing the cam cover. Is there much sealant out of the cracks?
I wouldn't think the oil viscosity would matter. I usually go 10w-30 after a head job. Probably a lifter going bad.
- 1666 Views
Last post by Redbox
- 982 Views
Last post by MoparWade
- 1752 Views
Last post by clifford06
- 21 Replies
- 3344 Views
Last post by rspi
- 22 Replies
- 7434 Views
Last post by bmdubya1198
