Steering issue
I have an 03 XC70. What it does is once you get the steering wheel past a certain point, right or left, it pulls the wheel over the whole way and you can hear the tires dragging like they would if it was in 4wd and trying to make a sharp turn. Any ideas what could cause such a thing?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Don't exactly get the description but these cars are known for worn/broken steering stops http://forums.swedespeed.com/showthread ... ring-Stops
Can try put some grease on it, or switch them to the other side
Other thing, if the tires are larger than the original spec they might be rubbing
- 3274 Views
Last post by chittychittybangbang
- 1244 Views
Last post by jbkeene
- 30 Replies
- 26977 Views
- 6073 Views
Last post by EngineeringBloke
- 1105 Views
