1994 850 antenna issue
My mast is stuck up and will not go down, if this is a bad motor how can I verify that? or perhaps just the mast.
- Year and Model: Many Volvos
- Been thanked: 75 times
You can usually tell if it is a mast or the motor by listening for the motor working with your head in the trunk while someone turns the radio on and off inside of the car. If you can hear the motor but the antenna doesn't extend or retract then most of the time the spine gear on the mast has broken off.
- Has thanked: 1846 times
- Been thanked: 1710 times
It can also be the mast has seized and the motor cannot move it. Sometimes just replacing the mast portion can resurrect a bad antenna. You can get a cheap mast for $10-15 or so from FCP and other suppliers from brands like MTC. I used one on an 850 project about 6 months ago and worked fine. Biggest problem with the antennas is people don't maintain them by cleaning the masts every couple of weeks with a wipe down of something like WD-40 on a rag.
- 2577 Views
Last post by mika
- 847 Views
Last post by mydamnvolvo
