Exhaust cam position sensor?
Hi, I need to change the timing belt and exhaust VVT on my 04 xc90. I bought the cam locking tool, and read that the dual VVT engines have 2 cam position sensors which need removed to install the tool. I can see the intake one but on the exhaust side all I see is the upper engine mount. Do I need to remove this? If so, how?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Maybe someone else can chime in... that has done it on that car... but I am 99% sure you will need to remove the mount to gain access to the back of the exhaust cam. It is something like 6 bolts one down low hard to see. If that car has an exhaust side position sensor then remove that to get to back of cam to install locking tool. I just did this on my C70 which had only an exhaust VVT and exhaust side cam position sensor. You can probably find a Robert DIY video to get the idea of removing.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
xyourobob
- Year and Model: 2004 XC90, 2011 XC60
- Been thanked: 4 times
You have to remove the air filter assembly and move the large fuse box sitting in front of the air filter assembly, this will give you access to the cam position sensor housing, I'm assuming you have a T6. I just did that on my T6 several times and thats what I did to gain access, no reason to remove the engine mount assembly.
cuhfs
xyourobob - Were you able to attach the cam locking tool too?
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
xyourobob
Yes I was, the hardest task of dealing with the exhaust cam position sensor is getting the housing cover off because the PCV system big pipe hoses make it difficult to get in there and disconnect the wiring harness from the cam position sensor housing. I removed the PCV hoses and put straight forward clamps on the hoses when I put it back together.
Putting the cam locking tool is fairly straight forward, just make sure you line up the cams with the cover and use a sharpi marker to accent the position marks on the cam when you do it.
- 23 Replies
- 2538 Views
- 1488 Views
Last post by iRenaissanceMan
- 1678 Views
Last post by rb61
- 8778 Views
Last post by FREEBUSINESSES
- 4067 Views
