Repetitive popping sound in transfercase?
I recently bought a 2000 v70xc...today the transmission or transfer case (idk) was whining (very r/c car like) during deceleration and on the freeway it made a large pop then the consecutive popping began, I feel like the epicenter is right under the driver seat . I removed the drive shaft to begin the troubleshooting and now although the sound is not at bad it is still popping and it is a bit rough going into reverse. Please help Volvo world
2000 V70xc
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
What do the fluids you've checked look like? Any idea of the previous service history - or lack of... ?
Being under it today showed a good amount of dark oil residue coming from the transfer case possibly the rear main seal I'm not sure but coming from the driver side. No record of transmission service. Engine fluids look golden and timing belt/WP done 10k ago.
2000 V70xc
- Has thanked: 2199 times
Probably the angle gear/transfer case has a failed drive sleeve between it and the transmission. It may have gone far enough to damage the angle gear to.
You will need to pull the angle gear housing to verify this.
Neil
Neil
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I'd remove the angle gear and drive for a while with it out and see if that kills the noise (I've been doing this for 7 years). See my method for retaining the angle gear sleeve in this thread, first page: viewtopic.php?f=1&t=79549&p=428967#top
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
What is required for your bypass, I'm super interestedecbsykes wrote: 03 Apr 2017, 04:14 I'd remove the angle gear and drive for a while with it out and see if that kills the noise (I've been doing this for 7 years). See my method for retaining the angle gear sleeve in this thread, first page: viewtopic.php?f=1&t=79549&p=428967#top
Thanks
2000 V70xc
Is your car a 4 speed auto or 5 speed? I think it is a 4 speed auto?
Do you know which trans it is? I believe it should be an AW40-42LE (sleeve part # 9181408) but you may have a AW55-50SN (sleeve part # 9495034).
Volvo lists the first part number a Discontinued. My version of Vida is older so maybe check if the part # has been superseded? The second one is still listed as available
The part # you listed is only for a manual trans in a P80 AWD up to 2000, but I read a thread which was not clear. It was for a 98 V70AWD but did not say if manual or auto. The owner bought the number you listed so maybe it is the new part #?
Check out this thread:
viewtopic.php?t=74978
- 775 Views
Last post by tingtang
- 1395 Views
Last post by volvo240student
- 568 Views
- 1724 Views
Last post by oragex
- 798 Views
Last post by oragex
