1993 850 dash speaker replacement
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 »
1993 850
Right dash speaker paper crumbled away when I accidentally touched it. Speaker says 8 OHM. I found an Altec Lansing A2723 4 OHM speaker in an old PC Speaker. What are the consequences of using it as the replacement?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
You can use 4 Ohm or 8 Ohm with no real issues, the radios aren't that picky. If you replace one on one side and don't match it on the other then there will be a loudness difference left to right so the way to go is to replace them in pairs. You can modify the mounting on any standard 3 1/2" automotive speaker to fit in the hole.
Paul-93-850
Thanks, Works great. Only did one side. Good enough.
