uneven running
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tiff
uneven running
Post by tiff »
I have a 1993 940s Torbo saloon. She is running very strange in that whilst cruising the revs increase about 500rpm, all the lights go bright and all the engine gauges react with the increase in revs.This only lasts for afew seconds at a time but is becoming more frequent. Even off load the fault is there. Can anyone give me an idea where to start
LaRy
Post by LaRy »
To me, it seems like you are getting over voltage. Sounds like a generator problem. The regulator in the generator is not working.
Maybe you are dropping the load from the battery. For that reason check also the connections between the generator and the battery including the thick ground cable. The ground cable is rather often broken due to vibrations.
