removing injectors
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
charlieruss
removing injectors
Post by charlieruss »
So, im trying to check my injectors, i dont know how to remove them, after i unbolt them do i twist the injector or pull it straight out? i appreciate the help! thanks!
CarVolvo
Post by CarVolvo »
the manual says...
1. relieve pressure in the system
2. disconnect the cable from the battery
3. disconnect the electrical main cable connector to the injector
4. detach the fuel hoses to the fuel rail.
5. detach the fuel rail mounting bolts
6.lift the fuel rail/injector assembly (so thats a pull gently)
7. dont forget to replace the "o" rings when you put them back!
good luck!
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
