Kid was driving home and car quit. In hot weather with AC running. Then car overheated and dumped coolant on the ground. I towed him home and ran a scan. Got 0342 which is camshaft position sensor error. Also got two other codes that I attributed to running the battery dead while towing him home. They both went away after battery recharged.
I replaced the camshaft sensor and the car still does not start. The 0342 DTC code still shows up. I don't know if it is new or if it is lingering. I had the battery disconnected for awhile during the swap of the sensor.
Should the 0342 code have gone away? Do I have to get it cleared before the car will start? Could the car have thrown the code again just from me trying to start it? (It did not start. Turns over a little slow. Seemed to fire a tiny bit, but that's it.)
99 S70 Turbo won't start
double_eagle20
- Year and Model: S70 1998, S70 1999
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
It sounds like you have a generic scan tool. 0342 would infer the sensor's signal is to low, or not strong enough. The signal is low enough to be vague and difficult to interpret. Or signal line shorted to ground.
Other cam issues can also cause this - like if there was a timing belt issue (slipped / broken). You might take a quick look at the timing belt and check all is where it should be. Especially since the water pump is also driven off the timing belt; if the water pump stopped turning it would cause a number of issues.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
double_eagle20
I will check the timing belt tomorrow. Thanks. Yes I do have generic (cheap) scanner. Do you know if the 0342 should have cleared due to the battery being disconnected? I'm wondering how I got a code without the car even starting. And would this code being set affect the car's performance (or starting)?
The ETM in this car has been hinky for a long time, but has kept on working. No codes set this time. ETM codes have set and cleared in the past.
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
If the car "overheated and dumped coolant" I would be looking to determine the cause of the overheating and the location from which this dump took place. It's possible that the camshaft position error was caused by a fault in the timing (broken belt, pulley, idler etc). Even if you replace the cam sensor if your timing if off you will get a repeat of the same code - it is entirely likely that the sensor is fine and doesn't need to be replaced. You won't be able to diagnose any of this without taking off the timing cover. Best case scenario you've just jumped a cog - worst case you might have toasted your valve train (don't ask me how I know this!)
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
double_eagle20
Thank you shegarty. I had assumed that the coolant dumped out of the overflow due to the car overheating due to the fan not working due to the low battery. But your comments and the previous comment have me worried about the belt jumping or breaking. As previously noted, I plan to check the timing belt today. I have a different vehicle to fix first before I get back to this one, but will post what I find under the timing belt cover when I get back to this project.
Thanks!
Thanks!
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Does it sound normal turning over, or does it sound lumpy/low on compression? I'd worry about the overheat, these engines are very sensitive to that.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
double_eagle20
It seems to turn over a little slow. Not sure what you mean by lumpy.
Thanks.
Thanks.
double_eagle20
If the car did get overheated and suffer damage, does that mean I'm screwed?
- Has thanked: 1498 times
- Been thanked: 3810 times
If junior shut the car down in seconds, not minutes , from coolant loss you should be ok. These cars are not too tolerant of running hot, though. The down scenario is head off for a new head gasket and/or valve job
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If the car shut itself off, it likely has a bad head gasket now. As mentioned, these cars do NOT take being overheated at all.
