Hi, there. My ignition lock on my 01 v70 recently stopped turning. It's stuck in position 0.
Steps so far:
1. Ordered new ignition lock keyed to my VIN from Volvo dealer.
2. Removed all electrial connectors, ignition switch, etc.
3. Removed the ignition lock from column (those shear bolts are fun).
4. PROBLEM: I can't complete the last step, removing the shifter lock cable from the lock. VIDA says lock should be in position 1, but I'm stuck in position 0...kind of a catch 22 going on here.
BTW, the relocker cap, spring, pin appears to be missing from my lock, maybe fell out sometime ago, but I'm reading that should not keep key from turning anyway.
I also tried freeing up the little stamped plate on bottom of lock, but no amount of fiddling with this lock will let me release the shifter cable.
Am I going to have to cut this thing open with my dremel to free up the cylinder to turn to position 1 and free the cable or what? Thanks. -Mike
replacing ignition lock, stuck in position 0, cable won't disconnect
- mp5802
- Year and Model: 2001 V70 T5
- Has thanked: 1 time
Update: I tried to drill the sides of my broken ignition lock to release the cylinder per locksmith youtube video, but had I no success. This lock is not "pot metal" but a tough alloy of some kind (also it's dangling under dash at this point). Short story: I cut the cable and discarded both lock and cable. Then, I removed the console and removed the remaining cable piece from shifter assembly. A new interlock cable cost me about $60. Done. Hint, if your work produces a SRS Air Bag message (codes), use your VIDA/DICE or other good ODB2 tool to clear the codes. (I used my icarsoft i906).
- 3101 Views
Last post by cn90
- 4195 Views
Last post by rfm77555
- 14 Replies
- 9447 Views
- 795 Views
Last post by cn90
- 13 Replies
- 4926 Views
Last post by plumsmooth
