Front end improvements
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
S60UT
Year and Model: 2000 V70R
Been thanked: 4 times
Post by S60UT »
I understand the P2 S60 is known for having a soft front end. But my S60 feels so soft compared to my BMW E46 touring. I have replaced lower control arms, sway bar end links and installed the IPD sub frame inserts. New struts and associated hardware to be purchased next. What have you guys done to improve the stiffness of your front ends. The steering seems so soft and sensitive like it wants to dart off the road. Is there any steering lash adjustments on these cars ?
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
One post is sufficient!
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Your other car might be causing a bias.
I'd try to find someone who knows how volvo's handle or pay a mechanic to assess the front end.
Mine was vague feeling, turned out to be soft tires and control arm bushings were shot.
I have those IPD sub frame bushings but the car doesn't feel like it needs them now.
Any slop in the tie rod ends?
Is the PS fluid decent?
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
Do you have the entire subframe bushings or the inserts?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
New front sway bar from XC90, new rear sway bar from V70R or S60R. Without rear sway bar it doesn't feel firm at all.
Also adjustable rear toe rods from IPD would help to set near-zero thrust angle, which is IMO impossible with stock rods.
jonesg
Post by jonesg »
Georgeandkira wrote: 04 Jul 2017, 11:26 Do you have the entire subframe bushings or the inserts?
I got blue inserts with some sort of lube. Never got around to installing them, can't find them anyway.
