Rear wiper not working but ticking
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
qwertyjjj
Year and Model: V70 2004
Has thanked: 1 time
Post by qwertyjjj »
The rear wiper has stopped working.
All fuses seem ok - tested with a multimeter.
I can hear it ticking in the back window even though the switch is off.
Turning the switch on and off makes no difference.
Any ideas what I can check?
I have a Vida dice if that will help...
qwertyjjj
Has thanked: 1 time
Post by qwertyjjj »
Bump...
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Are you certain the fuses in the REM are OK? These are rear mounted on the REM module.
You can command the rear wiper on in activations in Vida; this tells you if switch on the stalk is the culprit.
The ticking may be a faulty REM but let's check those REM fuses first.
