my 04 c70 just got loud up top behind the engine, I am thinking the way it went cracked ex manifold.
Need to get back there and see for sure.
I am hoping it is just the flex pipe.
Will take off sheild and see maybe tonight, working right now, may need to wait for morning
Just got loud!
- Has thanked: 292 times
- Been thanked: 765 times
The most common spot for the exhaust to break is a seam at the catalytic converter, but you can usually tell because the noise sounds like it is coming from right under the driver's seat, rather than from up top. The cat location is an easy fix, but the flex pipe is a fair bit more work.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
- Has thanked: 1 time
$40 weld, was flange to turbo from Cat pipe.
Removed it brought to my muffler guy, would not want to know what paying someone for the job would cost, prob over $600.
2004 c70 2.3HPT, s60 2.5T
tombrisk
- Year and Model: 2000 V70XC AWD
- Has thanked: 5 times
Reviving old Post, but good to know that it CAN be welded, the cat pipe just blew off the flange at the squirrel cage.
Thought I heard a slight rattle, full throttle blast identified the issue!
tombrisk
Hoping someone has the torque spec to remount my V70 cat back on to the turbo? The studs are out, I'll thread them back in, but I'd prefer to not have to get back down there
Thanks for tips
Thanks for tips
tombrisk
I've ordered book(s), but could one kind board member supply the torque for the turbo to cat flange torque, please?
Guessing between 31-49 per a generic chart
- Screenshot
- torque_specs.jpg (81.99 KiB) Viewed 934 times
- Has thanked: 1503 times
- Been thanked: 3817 times
A bit less.
20 Nm for the studs, 25 Nm for the nuts
Use new hardware for exhaust please, it’s the classy thing to do for the next gal/ guy.
