06 xc70 vs 09 xc90
Dadvid
Year and Model: 2000 s70
Post by Dadvid »
I'm considering buying one of these for my wife: 2006 xc70 5cyl turbo or 2009 xc90 3.2. I am partial to the xc90; i hear the 3.2 is kind of dull but reliable (like me) but my wife likes the look of the 70. They both have @100k miles. We would be happy with either but my main concern is durability for the next 100k. Which do you think would be the best bet?
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Is the '09 XC90 turbocharged? Perhaps all XC90's are. Turbos like premium fuel.
Service records are king here. Skipped oil changes/cheapo oil are bad.
Both have the more modern AWD system but both (I believe) run happier with matched tires.
Cost of each?
3.2 has a chain. The '06 needs a timing belt yesterday.
Do both cooling systems have blue coolant in them?
Do both drive straight down the highway with the steering wheel straight?
Are the wheels scuffed up?
How do they shift?
I'm in No.NJ and there's a 2008 XC70 NON-TURBO 3.2 w/46K and the bloke is asking $14,500. If I was in the market.....
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Let her pick.
Dadvid
Post by Dadvid »
Thanks Kahl. Sound advice!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Dadvid, Which xc90 to buy first generation that will help. I've got a few Repair Database posts that discuss buying a first gen XC90... most/all lead back to various MVS forum discussions.
Also -> Amazon link
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The best bet is the car that has had already repairs such as suspension, control arms...done at the main dealer.
The XC90 will cost more in repairs.
I would go with the XC70 (you don't want to hear the "I told you to get the XC70" later on ;)), only issue I think the AWD was fragile up to somewhere in the middle of 2006, if your had the weaker parts it will fail if not already failed - the car will keep going only the rear wheels won't have traction. The XC70 also needs a timing belt which is not a biggie, a local independent Volvo garage should replace it for less than $500 - the water pump should not be replaced with the first belt.
This is a list of repairs after @100k miles on a S60 - the XC have AWD plus a few others parts that may need repairs on top of it
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
The 3.2 6 is less reliable an engine as the 5 as long as the 5 has been WELL SERVICED.
Toss a coin, SERVICE RECORDS is what's most important considering both have 100K miles
Dadvid
Post by Dadvid »
Thanks guys. Great info!
