Light issues
- mydamnvolvo
- Year and Model: Lots
Light issues
there's more in the description of the video.
pnp switch?
also, doesn't like to shift into neutral. thinking reverse lights come on between reverse and neutral?
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
- Has thanked: 1500 times
- Been thanked: 3810 times
Okay - I give up - whats going on > Spurious light alert? How are the fronts?
- mydamnvolvo
The headlights are fine. It's like my car is possessed! And they only flicker like that when the car is on!
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
What "only flickers like that when the car is on"? No offense but that video showed me nothin'.
I couldn't read the warning window. Be more descriptive.
- mydamnvolvo
The message that says "bulb failure position light" Theres more information in the description of the video.
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
Ah...MVS plays the video in the thread box, we can't see the text description.
- mydamnvolvo
"was replacing tail light because message kept flashing in dashboard. Message only flashes when car is running, removed one reverse light, and 1 remained on, replaced, and suddenly both reverse lights wouldn't come on, and message remains flashing"
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
'position light' refers to the rear tail lamps (not the brake, turn, or reverse lamps). 4 bulbs.
These are touchy about using the exact OE specified European spec bulbs. US spec 'equivalent' bulb P/Ns, which auto parts stores often reference to these vehicles may technically fit but don't always match the Euro spec bulb with regard to wattage. In the video it appears the bottom pair is brighter than the top pair. I'd start there.
precopster
- Been thanked: 128 times
5W parking bulb in rear light fixture has bad contact. It's the long one which is hardest to reach by removing the speaker.
It can also be the parking bulb which is shared with the brake light bulb. Wattage is 21/5
Check them at night as you can't see 4 clear lights in there during the day
Twist it a little back and forth and watch the problems go away. Don't remove it as they are a bear to put back in. Just twist it one way then the other to wipe off surface corrosion.
The PNP is adjustable for angle with a large nut (18mm from memory) that allows 2 12mm bolts to be loosened and allow rotation of the PNP switch to the desired angle for optimum reverse light operation. The way I set these up is to set up a mirror behind the car reflecting the reverse light so while I make adjustment of the PNP so I can centre the PNP to where the reverse light goes on and off.
If you look at the wiring diagram for these things you need a programmer to figure it out,,,.mydamnvolvo wrote: ↑24 Jul 2017, 20:13 "was replacing tail light because message kept flashing in dashboard. Message only flashes when car is running, removed one reverse light, and 1 remained on, replaced, and suddenly both reverse lights wouldn't come on, and message remains flashing"
