I have a 1999 Volvo S70. I pulled the old alternator, bought a new one online and installed it two weeks later. When I went to hook it up I connected the large red wire (Hot) and a tiny wire (some sort of control wire from what I understand) but there was no ground wire I could remember or see. A guy at the parts store said it should always have a ground. Is there a ground on this alternator or is it naturally grounded because its attached to the engine?
Car seems to run fine. Alternator is putting out correct voltage. Guy from store says there is some noise in the line (could be a short). He also says my battery is almost dead (putting out 300 cold cranking amps) It's a rare high end battery that stores often misread so I'm not sure if there is any issue there.
Is there a ground I'm missing? And if so where does it attach?
1999 S70 Alternator wiring questions
thinkoutside1
- Year and Model: XC90 Sport 2007
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The only alternators that have a ground wire connection are ones that have rubber isoalting mounts. The 5 cylinder ones and new (2000-2004 s40/v40 and the 15 and later using the new 2 litre "Drive-E" engines) have direct to bracket or engine mounting so the case is grounded by way of the direct mount.
thinkoutside1
This is what I suspected. Thanks Jimmy for taking the time to reply!jimmy57 wrote: 06 Aug 2017, 20:14 The only alternators that have a ground wire connection are ones that have rubber isoalting mounts. The 5 cylinder ones and new (2000-2004 S40/V40 and the 15 and later using the new 2 litre "Drive-E" engines) have direct to bracket or engine mounting so the case is grounded by way of the direct mount.
- 20 Replies
- 4046 Views
Last post by bmdubya1198
- 20 Replies
- 7426 Views
Last post by tonie
- 1788 Views
Last post by sparks894
- 6425 Views
- 5618 Views
Last post by gnalan
