98 S70 Not working needles (rpm,speedometer,oil etc
SLKH
Year and Model: 1998 S70
Post by SLKH »
lights chk engine n service comes and dash is on. but the Speedometer, rpm,tachometer needles do not move as well as directional indicators which work externally but does not display on DB. All other instruments are OK ie. radio system, A/C, etc.
Instruction manual does not say which or what fuse applies if this problem is a fuse.
Would appreciate any comments ASAP.
Thank you, SLKH
Has thanked: 2200 times
Been thanked: 1852 times
Can you get the codes pulled? IT could be a communications problem, but not sure on a 98. I had many of the issues you list but it was a bad ABS module on a 2000 V70. It could be a bad connector on the Speedo unit. To access that you need to pull the dash top off to get in to see it clearly. Remove battery first as dash air-bag is connected to upper dash cover.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Mu guess is a defective ignition switch (the electrical portion sitting on the left side of the steering column).
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Second for the ignition switch. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
