1998 S 70 Control Topic is solved
seadoodealer
1998 S 70 Control
Has anyone had a problem with the cruise on your 1998 S-70? Ours just stopped working.
Guest
80% of the time it is vacuum leak, either under the battery tray or under the dash board. just replace the rubber elbows / connectors, sometimes the nylon lines may leak too. Especially if the battery acid has overflowed.
20% of the time it is the vacuum pump(under battery tray) or the connector to the vacuum pump or the cruise control electronics.
