Repeat serp belt tensioner failure
turtle1615
- Year and Model: 1998 v70 t5
- Has thanked: 2 times
My 98 v70 t5 had a bad serpentine tensioner when I got the car, it would jump around a lot and make a knocking type noise. I replaced it with a meyle unit and it was smooth and quiet. About 1000 miles later I'm having the exact same issue, the tensioner is jumping around and knocking. I thought i had spun a bearing its that loud. I can stick a screw driver down there and make the noise and jumping go away. Any ideas what would cause a repeat failure so quickly? All the other pulleys look and sound great. Maybe a stretched belt? It's not new but looks good.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You allready answered your question...MEYLE.
Meyle HD is excellent for suspension parts and engine mounts...the story ends there...but regular Meyle products are in the bottom of quality range for suspension parts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2197 times
- Been thanked: 1850 times
Only brand of tensioner I would use is OE Volvo. Too expensive if the part breaks! Once spent 3 hours trying to get an aftermarket tensioner (the later manual type and not the hydraulic as in 98 and earlier) to align the belt correctly and everytime I turned the engine over by hand for a couple of revolutions it would adjust itself out of alignment.
Fitted a Volvo one and worked first time no problem.
- Has thanked: 311 times
- Been thanked: 817 times
Neil its a serp tensioner here, not a timing belt one. So to OP: there are only "manual" (spring) types, not hydraulic.
I agree with misha the Meyle could be failing already due to poor manufacturing quality. When the serp tensioner gets noisy I've been putting on used ones until just this year I started buying new ones if/as I find failures. Have only replaced one this year. The tensioner part isn't usually a problem on an old used one, you can just buy replacement pulley(s). I bought Volvo on those, I just don't want to deal with failing aftermarket parts. Too many cars in the fleet right now for that.
- 20 Replies
- 17335 Views
Last post by Hurtfeelings
- 15 Replies
- 3212 Views
Last post by F250
- 1120 Views
Last post by soulvoid21
- 3094 Views
Last post by bharman
- 4116 Views
Last post by cn90
