V70 Door lock and temperature glitches
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Showtime
Post by Showtime »
Hi,
I have a 2001 V70 that has an intermitent problem with the RH door lock being inop and making random clicking noises...at the same time the outside temperature will go blank...when the door starts working the temp comes back.
I tried disconnecting the battery w/o any change. I am figuring it might be a bad plug somewhere between the door and the computer. Any ideas?
Thanks....
Steely
Post by Steely »
Saw this in another post:
http://www.bulldogsecurity.com/
Scroll down to Volvo, next to V70, then pick your year.
Sounds like a short, but then you knew that.
Check the list, see if either of your problems have share a wire.
8)
'01 V70 T5
Showtime
Post by Showtime »
Nothing seems to fit on my list. With the affected services all in the same location, and affected at the same time, it sounds like a plug/connection issue...just wondering if anybody knows the location of the likely culprit.
