2004 s40 oil leak in timing belt area
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
VVT (Variable Valve Timing) hub.
Inspect closely and don't be fooled into thinking that it's just camshaft seals.
VVT hub failures are probably more common than seals.
I learned the hard way and changed the cam seals only to find out that it was the VVT hub.
So I had to do the whole job over again.
Pull the covers and clean everything that you can inside there to make an accurate diagnosis.
It's not a terribly difficult repair if you are really good at wrenching. But you do need some specific tools, a good repair manual and some mechanical knowledge.
Nice to see someone else in CT with a S40!
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
I just fixed my VVT hub as it was bathing the entire engine compartment to some degree. See the thread I posted on doing the repair. You will need a cam locking tool. To repair the hub, you will need a locking pliers with new jaws, three M7 x 16mm button head socket screws and the replacement o-rings. You should get the Viton rings. I have an extra set if you need them. Some guy on an auction site sells one of them but not the pair you need. You may as well replace the other seals on the timing belt side of the engine too. Let us know what we can do to help you.
Regards - B.
Regards - B.
- 16 Replies
- 7176 Views
Last post by erikv11
- 13 Replies
- 5907 Views
Last post by lcc014
- 5280 Views
Last post by jimmy57
- 23 Replies
- 17203 Views
Last post by jonesg
- 20 Replies
- 17446 Views
Last post by Hurtfeelings
