Buying advice for S60R/V70R Manual Transmission
jcgirton
Year and Model: 2006 Volvo S60R
Has thanked: 2 times
Post by jcgirton »
I’ve been looking to find a 2004 - 2007 S60R (seems rare so far) or V70R (impossible to find) with a manual transmission - any advice on what to watch out for?
Reason: added image and tags, edited title
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Depends on mileage of course. awd working (should not be able to turn the shaft by hand), clogged pcv, worn shock absorbers ($$$), control arms, slave cylinder on manual
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Yes, manual R cars are rare. You'll need patience while looking. Post a new "WTB: 2004-2007 R manual" topic in Volvo Classifieds forum.
Here are my notes from buying, Stage-0 it, and owning a 2004 V70 R auto.
Post questions here or in those topics, whichever makes more sense.
Also -> Amazon link
jcgirton
Post by jcgirton »
Your V70R looked really nice - I've been reading through some of the links, I've been trying to figure out what can go wrong with the AWD system, (my S60 is just FWD) - people have posted about the angle gear, the part is expensive but people posted directions to replace it and didn't make it seem like it was that bad of a job (please correct me if I'm wrong) - are there any other known issues with it? is the awd system fairly easy to work on yourself?
The manual transmission looks like it had issues with the slave cylinder but it looks like there was a fix for the part so if it has been replaced it shouldn't have any more issues? Also it doesn't look like you can really replace just the slave cylinder, if the clutch was replaced should it have the newer slave cylinder at this point?
oragex
Post by oragex »
jcgirton wrote: 18 Nov 2017, 08:57 Your V70R looked really nice - I've been reading through some of the links, I've been trying to figure out what can go wrong with the AWD system, (my S60 is just FWD) - people have posted about the angle gear, the part is expensive but people posted directions to replace it and didn't make it seem like it was that bad of a job (please correct me if I'm wrong) - are there any other known issues with it? is the awd system fairly easy to work on yourself?
If they replaced the slave cylinder, they had to drop the transmission so most probably they've replaced the clutch and the pressure plate (another point on the manual transmission, when the slave fails it leak fluid on the clutch but also on the pressure plate which must be replaced). If the repair was done recently, test well the clutch. If they didn't replace the pressure plate, good chances are it will need replaced. And yes, along with a clutch job on this car the slave must be replaced because even Volvo replacement slaves are known to sometimes fail again (it was a weak design)
For the awd there are several videos on Youtube, it'll give you a great idea about the repair
Don't forget about the extremely expensive 4C struts/shocks that go around 100k miles or so
jcgirton
Post by jcgirton »
Thank you guys! And thank you oragex, I think you’ve helped me every time I’ve posted a question and I really appreciate it!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yes there are several other wear items in the AWD. Angle gear is the most common, and usually the collar goes out with the angle gear.
Post by erikv11 »
Here's an 05 S60R manual in Chicago, condition appears decent but no mention of suspension work done yet ... https://chicago.craigslist.org/chc/cto/ ... 01962.html
