Squeal after brakes, axles, wheel bearing
mkc1
Year and Model: 850 GLT 1997
Has thanked: 27 times
Been thanked: 10 times
Post by mkc1 »
I recently had the front pads and rotors, CV axles, and one wheel bearing replaced. The rear pads, rotors, and calipers were also replaced. I now have a squeal at low speeds that varies with the speed of the car, but not with pressure on the brake pedal.
Is this likely to be a brake issue or perhaps something else like the dust guard rubbing on something. I wasn't sure if the common 'brake squeal with non-OEM pad' problem only occurred when braking or was constant.
Thanks!
Michael
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Perhaps the dust guard is bent at some wheel
mkc1
Post by mkc1 »
Thanks oragex.
The main squeal is definitely coming from the front driver's-side. The wheel bearing was replaced on the passenger side so it shouldn't be that. The car also pulls to the left -- I assumed the alignment was messed up by the bearing replacement. With the car pulling to the left going forward (and to the right going in reverse!) and the squeal I wonder if the left caliper isn't seized or sticking on the guide pins. I'll try to take a look when it's a bit warmer.
Has thanked: 1613 times
Been thanked: 4077 times
Check the calipers after a 10 minute run to see if they are hot...douse a cup of water and listen for boiling. Compare to the other side.
If you drive on sticking calipers, you will ruin your new Pads!
mkc1
Post by mkc1 »
No appreciable boiling...both sides about the same.
I did notice that the squeaking/pulling tire was about 15 PSI low so I aired it up and went for a drive. Seems better, but not completely fixed. I also noticed that bouncing any corner of the car produces a squeal similar to the one I get driving at low speed.
Not sure if that gives any more clues? Something suspension related maybe? I was thinking maybe the sway bar bushings but I think those tend to clunk rather than squeal?
(I should also mention that the winter tires (on steel rims) were put on at the same time the rest of the work was done and that I have noticed changes in squeaking/noises between the all-season and the winter tires before -- like more squeaking/squealing when getting out of the car.)
Has thanked: 2215 times
Been thanked: 1853 times
It could be the parking brake shoes have delaminated or a parking brake cable has jammed causing the parking brake shoes to drag.
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Post by jtp »
A front tire 15 psi low is going to cause a pull to the side of that tire.
Id check all the dust shields and try to narrow down the wheel where the squealing seems to be coming from.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
mkc1
Post by mkc1 »
I'm fairly certain it's coming from the front driver's side. Airing up the tire helped a bit but it's still pulling and squealing. Will take the tire(s) off when it's not -15C (5F) out. Here's a video. At the beginning the brakes aren't applied at all. Applying them doesn't seem to change the squeal much. A similar short squeal is heard when I get out of the car and another when I bounce the rear driver's-side corner.
Dust shield is the most likely. IT is easily knocked out of shape and bent into the rotor. Similarly easy to bend back also.
Rear brakes are most likely the parking brake shoes de-laminated and dragging, but could also be seized or partly seized parking brake cables causing the parking brakes to drag, and lastly the rear calipers are prone to seizing or the pads sticking in them. Time for a rear brake service.
mkc1
Post by mkc1 »
scot850 wrote: 21 Dec 2017, 10:46 Time for a rear brake service.
Thanks, Neil. Perhaps you didn't notice in my original post but all this $#!+ started after a brake service! :x
