Heater only works when going over 60mph
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
19woodstock50
Year and Model: 2004 1/2 s40
Post by 19woodstock50 »
I have a 2004 1/2 S40. Heater blower work fine but will only blows warm air when you are travailing over 65mph. Temp gauge comes up to temp as normal. As soon as you get below 65mph it starts blowing cold. 65 and above no problem. Any clues?
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
Bad head gasket?
But then again, the temp gauge coming up as normal does suggest normal cooling.
Maybe clogged cooling channels or failing/slipping water pump? What about lower speeds at higher revs?
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
My vote goes to clogged channels - most likely in the heater core itself. If the water pump were failing to such an extent as to get no flow to the heater core at lower RPMs I would expect you to see an elevated engine temperature gauge/indication when idling for more than a few minutes. If the coolant isn't OE-blue colored there's no telling what (cheap stuff that isn't appropriate for these cars) was put in there. Corrosion=particulates stirring around which in my experience the heater core will usually plug up first with the radiator to follow. There's also another possibility: a hose was replaced at some point in the past with generic non-formed hose, or one of the hoses collapsed at a bend resuling in a kink restricting flow like you'd get when you get a kink in a garden hose.
19woodstock50
jvl wrote: 16 Dec 2017, 10:27 Bad head gasket?
I will have to try the higher revs at a lower speed. Thanks
jvl
Post by jvl »
mrbrian200 wrote: 16 Dec 2017, 10:52 My vote goes to clogged channels - most likely in the heater core itself. If the water pump were failing to such an extent as to get no flow to the heater core at lower RPMs I would expect you to see an elevated engine temperature gauge/indication when idling for more than a few minutes.
Well... to my own surprise as well: I used to have a Land Rover that suffered from the impeller slipping on the water pump axle, was at the verge of failing but it wouldn't always slip. Took me a while to figure that out. Water pump replacement was easy on that car, took 2 hours.
Never done one on a Volvo, so wouldn't know about those.
But check for coolant flow at high revs amd lower speeds as well! Might indeed as well be flow restriction: non original hose or twisted hose, or maybe sludge in head?? Was any 'leakstop' used on this car??
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
How are the thermostat and the water pump?
19woodstock50
jvl wrote: 17 Dec 2017, 14:24
No leak stop was used.
